06-28-2013 01:24 PM - edited 03-21-2019 07:31 AM
06-28-2013 02:22 PM
Hello Mike,
It is good to add a route on the UC itself to point from which gateway it should go for the Internet.
Under command line:
ip route 0.0.0.0 0.0.0.0
HTH,
Alex
*Please rate helpful posts
06-28-2013 02:37 PM
can you do this using cca? also i can ping the gateway from 10.1.10.1 and 10.1.1.1 in cca.
06-28-2013 02:43 PM
Hello Mike,
You may ping them but if they do not know that they should go out from this gateway they cannot reach Internet.
You may try setting this under internet connection in CCA.
HTH,
Alex
06-28-2013 03:13 PM
so you want me to add a static route?
thanks for your help
07-04-2013 09:30 AM
if i have a sip line no internet plugged into wan on uc540. system is not able to access the internet but when it does dhcp for 192.168.0.0 network from the server 2008 it has internet..i can ping the default getway 192.168.0.253 from 10.1.1.1. 10.1.10.1 but no internet. any help would be great
