04-20-2011 02:21 AM - edited 03-21-2019 03:58 AM
Outgoing calls are fine.
When a call comes in fro PTT on my BRI lines I can see it has the correct digits, but a dial-peer is not matched.
000441: Apr 20 09:12:33.395: //-1/290A9D338008/CCAPI/cc_api_display_ie_subfields:
cc_api_call_setup_ind_common:
cisco-username=
----- ccCallInfo IE subfields -----
cisco-ani=7500026140
cisco-anitype=2
cisco-aniplan=1
cisco-anipi=0
cisco-anisi=3
dest=224232
cisco-desttype=0
cisco-destplan=1
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-lastrdn=
cisco-rdntype=-1
cisco-rdnplan=-1
cisco-rdnpi=-1
cisco-rdnsi=-1
cisco-redirectreason=-1 fwd_final_type =0
final_redirectNumber =
hunt_group_timeout =0
000442: Apr 20 09:12:33.395: //-1/290A9D338008/CCAPI/cc_api_call_setup_ind_common:
Interface=0x87894520, Call Info(
Calling Number=7500026140,(Calling Name=)(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed),
Called Number=224232(TON=Unknown, NPI=ISDN),
Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE,
Incoming Dial-peer=1000, Progress Indication=NOT END TO END ISDN(1), Calling IE Present=TRUE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
000443: Apr 20 09:12:33.395: //-1/290A9D338008/CCAPI/ccCheckClipClir:
In: Calling Number=7500026140(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed)
000444: Apr 20 09:12:33.395: //-1/290A9D338008/CCAPI/ccCheckClipClir:
Out: Calling Number=7500026140(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed)
000445: Apr 20 09:12:33.395: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
000446: Apr 20 09:12:33.395: :cc_get_feature_vsa malloc success
000447: Apr 20 09:12:33.395: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
000448: Apr 20 09:12:33.395: cc_get_feature_vsa count is 1
000449: Apr 20 09:12:33.395: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
000450: Apr 20 09:12:33.395: :FEATURE_VSA attributes are: feature_name:0,feature_time:2312240040,feature_id:115
000451: Apr 20 09:12:33.395: //115/290A9D338008/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Call Info(Calling Number=7500026140(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed),
Called Number=224232(TON=Unknown, NPI=ISDN))
000452: Apr 20 09:12:33.399: //115/290A9D338008/CCAPI/cc_process_call_setup_ind:
Event=0x87820F30
000453: Apr 20 09:12:33.399: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Try with the demoted called number 224232
000454: Apr 20 09:12:33.399: //115/290A9D338008/CCAPI/ccCallSetContext:
Context=0x89A14A5C
000455: Apr 20 09:12:33.399: //115/290A9D338008/CCAPI/cc_process_call_setup_ind:
>>>>CCAPI handed cid 115 with tag 1000 to app "_ManagedAppProcess_Default"
000456: Apr 20 09:12:33.399: //115/290A9D338008/CCAPI/ccCallSetupAck:
Call Id=115
000457: Apr 20 09:12:33.399: //115/290A9D338008/CCAPI/cc_api_set_transfer_info:
Transfer Number=, Transfer Reason=0x0
000458: Apr 20 09:12:33.399: //115/290A9D338008/CCAPI/ccGenerateToneInfo:
Stop Tone On Digit=TRUE, Tone=Dial Tone,
Tone Direction=Network, Params=0x0, Call Id=115
000459: Apr 20 09:12:33.403: //115/290A9D338008/CCAPI/ccSetDigitTimeouts:
Initial Digit Timeout=-1000(ms), Inter Digit Timeout=-1000(ms)
000460: Apr 20 09:12:33.403: //115/290A9D338008/CCAPI/ccSetDigitTimeouts:
Call Entry(Inter Digit Timeout=10000(ms), Initial Digit Timeout=10000(ms))
000461: Apr 20 09:12:33.403: //115/xxxxxxxxxxxx/CCAPI/ccCallReportDigits:
(callID=0x73, digit_event=0x1, enable=TRUE, consume=FALSE)
000462: Apr 20 09:12:33.403: //115/290A9D338008/CCAPI/ccCallReportDigits:
Enabled=TRUE, Call Id=115
000463: Apr 20 09:12:33.403: //115/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
(vdbPtr=0x87894520, callID=0x73, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
000464: Apr 20 09:12:33.403: //115/290A9D338008/CCAPI/cc_api_call_report_digits_done:
Enabled=TRUE, Disposition=0x0, Interface=0x87894520, Call Id=115
000465: Apr 20 09:12:33.403: //115/290A9D338008/CCAPI/cc_api_call_report_digits_done:
Call Entry(Initial Digit Timeout=15000(ms), Inter Digit Timeout=10000(ms))
000466: Apr 20 09:12:33.487: %ISDN-6-CONNECT: Interface BRI0/2/1:2 is now connected to 7500026140 N/A
000467: Apr 20 09:12:35.231: %ISDN-6-CONNECT: Interface BRI0/2/1:1 is now connected to N/A N/A
000468: Apr 20 09:12:35.231: %ISDN-6-DISCONNECT: Interface BRI0/2/1:2 disconnected from 7500026140 , call lasted 1 seconds
000469: Apr 20 09:12:35.231: //115/290A9D338008/CCAPI/cc_api_call_disconnected:
Cause Value=16, Interface=0x87894520, Call Id=115
ephone-4[3] Mac:1CDF.0F4A.985E TCP socket:[2] activeLine:0 whisperLine:0 REGISTERED in SCCP ver 8/8 max_streams=1 SPCP ver 1/1
mediaActive:0 whisper_mediaActive:0 startMedia:0 offhook:0 ringing:0 reset:0 reset_sent:0 paging 0 debug:0 caps:12
IP:192.168.3.13 1024 SPA502G keepalive 10 max_line 1 available_line 1
button 1: dn 232 number 224232 CH1 IDLE CH2 IDLE
Preferred Codec: g711ulaw
calls from ip phone to ip phone work fine using the same digits.
There are no translations patterns in place
Does anyone have an idea why this would not be matching
04-21-2011 04:28 AM
Because something is wrongly configured.
04-21-2011 11:46 AM
Looks like dial-peer 1000 is being matched.
You might want to post your config.
Don C.
04-26-2011 01:19 AM
Basically, the issue was IOS.
I was running uc500-advipservicesk9-mz.124-24.SB on a UC540 stratight out of the box.
I upgraded to uc500-advipservicesk9-mz.151-2.T2 and this resolved the issue.
They are not found on the cisco download software site, but rather, here in supportforums under UC500 software packs:
