02-03-2014 01:38 PM - edited 03-21-2019 08:03 AM
HI,
I am currently using a UC540W and have it setup to ring the Blast group and then transfer to Voice Mail.
Sip Provider is VoIP-Unlimited
I have configured the prefered codec to G729r8, and allowed transcoding. Everything was working well untill, I call from an EE Mobile phone or orange/Tmobile phone and then the mobile has no ring tone and instead of going to VM it cuts off, (works perfectly from another mobile provider and landline etc), upon checking the traces I noticed it was trying to use G711alaw codec, so I added it to below for transcoding, but with no luck. also if i call from the EE phone and answer it and then transfer it to another number and let it goto vm the transcoder shows the call also transcodes the hold music etc fine. also noticed on the sip traces from the sip trunk provider that EE and Orange are direct from EE etc as sip trunks. and not trough the pstn and the providers end. I did get this to work earlier but I reloaded the uc and not it won't work.
any ideas would be greatful.
voice class codec 1
codec preference 1 g729r8
codec preference 2 g729br8
codec preference 3 g711ulaw
codec preference 4 g711alaw
voice class codec 2
codec preference 1 g711ulaw
codec preference 2 g711alaw
sccp ccm group 1
associate ccm 1 priority 1
associate profile 2 register mtpe8b7480751a0
associate profile 1 register confprof1
dspfarm profile 2 transcode
description CCA transcoding for SIP Trunk VoIP Unlimited
codec g711ulaw
codec g729ar8
codec g729abr8
maximum sessions 10
associate application SCCP
dspfarm profile 1 conference
description DO NOT MODIFY, active CCA conference profile - CCA2.0 codec711
codec g729br8
codec g729r8
codec g729abr8
codec g729ar8
codec g711alaw
codec g711ulaw
maximum sessions 1
conference-join custom-cptone CCAjointone
conference-leave custom-cptone CCAleavetone
telephony-service
sdspfarm conference mute-on 111 mute-off 222
sdspfarm units 5
sdspfarm transcode sessions 10
sdspfarm tag 1 confprof1
sdspfarm tag 2 mtpe8b7480751a0
conference hardware
Below is when I placed the call on hold
UC_540#sh dspfarm all
Dspfarm Profile Configuration
Profile ID = 2, Service = TRANSCODING, Resource ID = 1
Profile Description : CCA transcoding for SIP Trunk VoIP Unlimited
Profile Service Mode : Non Secure
Profile Admin State : UP
Profile Operation State : ACTIVE
Application : SCCP Status : ASSOCIATED
Resource Provider : FLEX_DSPRM Status : UP
Number of Resource Configured : 10
Number of Resource Available : 10
Codec Configuration: num_of_codecs:4
Codec : g729abr8, Maximum Packetization Period : 60
Codec : g729ar8, Maximum Packetization Period : 60
Codec : g711ulaw, Maximum Packetization Period : 30
Codec : g711alaw, Maximum Packetization Period : 30
Profile ID = 1, Service = CONFERENCING, Resource ID = 2
Profile Description : DO NOT MODIFY, active CCA conference profile - CCA2.0 cod
ec711
Maximum conference participants : 8
Codec Configuration: num_of_codecs:6
Codec : g729br8, Maximum Packetization Period : 60 , Transcoder: Not Required
Codec : g729r8, Maximum Packetization Period : 60 , Transcoder: Not Required
Codec : g729abr8, Maximum Packetization Period : 60 , Transcoder: Not Required
Codec : g729ar8, Maximum Packetization Period : 60 , Transcoder: Not Required
Codec : g711alaw, Maximum Packetization Period : 30 , Transcoder: Not Required
Codec : g711ulaw, Maximum Packetization Period : 30 , Transcoder: Not Required
SLOT DSP VERSION STATUS CHNL USE TYPE RSC_ID BRIDGE_ID PKTS_TXED PKTS_RXED
0 1 28.3.5 UP 2 USED xcode 1 7 97 70
0 1 28.3.5 UP 2 USED xcode 1 6 97 97
0 1 28.3.5 UP N/A FREE xcode 1 - - -
0 2 28.3.5 UP N/A FREE xcode 1 - - -
--More-- banner login ^Cisco Configuration Assistant. Version: 3.2 (3). Thu Dec
12 16:01:20 GMT 2013^
UC_540#sh sip-ua calls
Total SIP call legs:2, User Agent Client:0, User Agent Server:2
SIP UAC CALL INFO
Number of SIP User Agent Client(UAC) calls: 0
SIP UAS CALL INFO
Call 1
SIP Call ID : 18440254-3600451332-786746
State of the call : STATE_SENT_ALERTING (14)
Substate of the call : SUBSTATE_NONE (0)
Calling Number : 00000000000
Called Number : 00000000000
Bit Flags : 0x8C4001C 0x10000100 0x404
CC Call ID : 357
Source IP Address (Sig ): XXX.XXX.XXX.XXX
Destn SIP Req Addr:Port : [XXX.XXX.XXX.XXX]:5060
Destn SIP Resp Addr:Port: [XXX.XXX.XXX.XXX]:5060
Destination Name :XXX.XXX.XXX.XXX
Number of Media Streams : 1
Number of Active Streams: 0
RTP Fork Object : 0x0
Media Mode : flow-through
Media Stream 1
State of the stream : STREAM_ADDING
Stream Call ID : 357
Stream Type : voice+dtmf (1)
Stream Media Addr Type : 1
Negotiated Codec : g711alaw (160 bytes)
Codec Payload Type : 8
Negotiated Dtmf-relay : rtp-nte
Dtmf-relay Payload Type : 100
QoS ID : -1
Local QoS Strength : BestEffort
Negotiated QoS Strength : BestEffort
Negotiated QoS Direction : None
Local QoS Status : None
Media Source IP Addr:Port: [XXX.XXX.XXX.XXX]:16744
Media Dest IP Addr:Port : [XXX.XXX.XXX.XXX]:52158
Options-Ping ENABLED:NO ACTIVE:NO
Call 2
SIP Call ID : 5bfc6e61-c0e6a074-b23b1@91.151.2.130
State of the call : SIP_STATE_OPTIONS_WAIT (27)
Calling Number : pinger
Called Number :
Bit Flags : 0x40000C 0x10000104 0x10
CC Call ID : 356
Source IP Address (Sig ):XXX.XXX.XXX.XXX
Destn SIP Req Addr:Port : [XXX.XXX.XXX.XXX]:0
Media Stream 1
State of the stream : STREAM_IDLE
Stream Call ID : -1
Negotiated Codec : No Codec (0 bytes)
Codec Payload Type : 255 (None)
Negotiated Dtmf-relay : inband-voice
Dtmf-relay Payload Type : 0
QoS ID : -1
Media Source IP Addr:Port: [81.140.22.14]:0
Number of SIP User Agent Server(UAS) calls: 2
SIP UAC CALL INFO
SIP UAS CALL INFO
Call 1
State of the call : STATE_ACTIVE (7)
Bit Flags : 0x8C4401C 0x10000100 0x4
CC Call ID : 357
Number of Active Streams: 1
Media Stream 1
State of the stream : STREAM_ACTIVE
QoS ID : -1
Call 2
Called Number :
CC Call ID : 356
Media Stream 1
Stream Call ID : -1
QoS ID : -1
Media Source IP Addr:Port: [XXX.XXX.XXX.XXX]:0
pcap from voip provider shows the 180 ringing going back to the sip trunk.(I'll call them tomorrow and get them to look into this)
02-04-2014 06:28 AM
Hi Today I have removed the DDI's from the sip trunk and removed the firewall. and tested
When you call the main number now you get the 140 ringing tone. ()when called from my EE mobile)
I have added in a new firewall (ACL firewall) to the UC540 and it seams to be working with exception to the DDI's, only issue I get now is that once the time expires for the ring group it's not transfering the call to the Voicemail.and ends the call these calls are presented as a G711alaw and not G729 or G711ulaw. I have transcoding in place but it's not picking up the call and transcoding it.
When I called the trunk provider they emailed the following (cut and pasted)
This is a firewall issue at your end.
You need to use either no nat with port forwarding or full nat with stun enabled.
I also suggest you to check SIP ALG and IDS are disabled as this could be rewriting the headers.
as they are seeing a port chage request mid way through the call and a http 500 error on the traces.
any advice would be great.
