Please be advised, the GuideMe Wizard is no longer available on the Small Business Support Community. For search capability please use the community search field to find content related to Cisco Small Business documents, videos, and discussions.
3206
Beginner
UC540 Voicemail PIN reset
I can see from the dicussions various posts about resetting a voicemail PIN through CCA and it not being possible and you need to use the GUI at 10.1.10.1.
I have tried to browse to the GUI and it doesn't work, if i try to ping 10.1.10.1 i get a response from the IP of the UC540.  I know you can do it via CLI:
UC540#service-module integrated-Service-Engine 0/0 session
se-10-1-1-117# user (username) pin (value)
However when i try the service-module integrated-Service-Engine 0/0 session command it errors with connection refused by remote host.
ANy ideas?
Everyone's tags (4)
1 ACCEPTED SOLUTION
Hall of Fame Master
Cannot reach CUE is due to routing problem, e.g. you internet router knows nothing about 10.1.10.x
For CLI access, do a 'session clear' before 'session'.
1 REPLY 1
Hall of Fame Master
