03-13-2012 07:43 PM - edited 03-21-2019 05:30 AM
I just installed VWIC2-2MFT-T1/E1 on UC540 and until now I don't see any problems. I can see the card in "show diag" and the controller E1 0/2/0 and 0/2/1 interfaces but when I try to configure one of them it seems like the configuration is not saved meaning I don't see any configuration applied in "show run".
Would it mean that this card is not supported on UC540 but only VWIC2-1MFT-T1/E1?
Thanks in advance for any suggestions.
Remi
03-13-2012 09:20 PM
Hi Remi,
Can you please provide us with your running configuration (Please remove al sensitive data), then we can assist further
Also is this system CLI managed and not CCA managed?
CCA should configure this for you easily and ensure that the right configuration is propagated throughout the entire configuration.
Cheers,
David.
03-14-2012 05:38 AM
Thanks David.
The whole running configuration is not relevant here however I will show you the bit where the problem is:
Abstract from the running config:
controller E1 0/2/0
framing NO-CRC4
line-termination 75-ohm
description ***Digital Voice Trunk E1 - TELMEX***
controller E1 0/2/1
process-max-time 50
The config I am trying to apply:
UC540(config)#controller E1 0/2/0
UC540(config-controller)# framing NO-CRC4
UC540(config-controller)# line-termination 75-ohm
UC540(config-controller)# ds0-group 0 timeslots 1-10 type r2-digital r2-compelled ani
UC540(config-controller)# cas-custom 0
The channel must be a CAS channel
After cas-custom 0 I get this error.
But after applying the line above I don't see anything in the running config, basically is the same:
controller E1 0/2/0
framing NO-CRC4
controller E1 0/2/1
process-max-time 50
Do you know why I get this error?
Thanks in advance.
