12-13-2010 02:08 AM - edited 03-21-2019 03:24 AM
How can we back up the Voicemail boxes? CUE has a back up option, but I do not know if it is backing up the VM. The configurations goes to 192.168.10.12/cue, so is that located on the PC that has that address?
Thanks!
Ashish
12-13-2010 06:46 AM
CCA does backup Voice Mails too when you run COnfiguration Archive. It backs up to the PC running CCA.
12-22-2010 01:24 AM
Thank your for your reply. Okay I have many back ups. I am going to do a fresh install and the new update on a UC520 due to many glitches on the System. I am going to create all the extensions again. I should not be able restore the configuration to through CCA because its going to be a fresh configuration. I do not think I can just restoe the VM back in the VM Boxes, so how can send the users their VM that ones that are already backed up? Are they wav files? Do I need a tool to extract them?
