UC560 & Cisco AnyConnect Secure Mobility Client
syed_quadri
Hi Guys,
Please can anyone suggest which AnyConnect package I should be using on UC560 ?
I have installed Web Deployment Package For Windows Platforms - 3.1.02040 and I am having issues.
Cheers
Syed
Hello Syed,
Recommended one is Anyconnect 2.5.6005.
HTH,
Alex
*Please rate helpful posts
paolo bevilacqua
There are posts about, here or other forums if you search.
I don't remember the details, but some versions are meant to work with the ASA, and work poorly, if at all, with IOS.
Of course one would expect to be advised about that, even at the connection time, but unfortunatly with Cisco, certian things are they way they are.
Hello Syed,
HTH,
Alex
Thanks Alex
I am using 2.5.6005 and its working fine.
