Can the UC560 be setup to use IP based authentication instead of SIP authentication for flowroute?
Hi Thomas,
Yes it can. If you are using CCA under the SIP trunk configuration>Service Provider settings, select the option "Do not register DID's"
Also Flowroute will need to make sure your public IP is allowed.
I hope this helps.
Chris
