05-21-2012 07:13 PM - edited 03-21-2019 05:49 AM
I have a full PRI with AT&T 23B+1D, running in primary-ni mode, north american 7-digit. I am able to place local and national calls but unable to dial international. I dial 9 then 011 then the international number get a fast busy signal. I have a ticket opened with AT&T they keep sending the ticket to a translation group but have not heard back yet. I can see the international dial plan within CCA. What can I do to check that it is not the phone system having this issue.
Software pack 8.2
Solved! Go to Solution.
05-21-2012 09:57 PM
try
interface x/y/z:23
isdn map . unknown unknown
I whish Cisco would understand once for all that what they are doing with silently changing plan/type is simply wrong.
05-21-2012 09:57 PM
try
interface x/y/z:23
05-21-2012 10:44 PM
Well that definetly fixed it I ran "isdn map address 011.* plan unknown type unknown"
05-21-2012 10:48 PM
Very good, thanks for the nice rating and good luck!
