UC560 Loopback entries
Greetings!
  My UC560 has several loopback entries, I assume it's CCA's bipolar disorder. Here's an example:
interface Loopback1
ip address 50.50.50.50 255.255.255.0
ip nat inside
ip virtual-reassembly in
interface Loopback2
ip address 51.51.51.51 255.255.255.0
ip nat inside
interface Loopback3
ip address 52.52.52.52 255.255.255.0
ip nat inside
interface Virtual-Template2 type serial
ip unnumbered Loopback1
ip nat inside
interface Virtual-Template3 type serial
ip unnumbered Loopback2
ip nat inside
interface Virtual-Template4 type serial
ip unnumbered Loopback3
ip nat inside
Thoughts? Is it OK to get rid of these?
-Renato
David Trad
Hi Renato,
I have not seen this type of configuration in a very long time...
The UC-560 these days does not use the Loopback setup anymore, it creates a VLAN-90 as a replacement which is a more logical way of doing things in my opinion.
Those Loopbacks look oddly familiar to really old configuration or loopbacks for VPN/VLAN configurations which are additional to the standard configuration.
The current way CCA sets it up is as follows:
interface Vlan90
description $FW_INSIDE$
ip address 10.1.10.2 255.255.255.252
ip access-group 103 in
ip nat inside
And then adds the other associated configuration to go with it.
Was this an upgrade to an older configuration or from scratch?
I would not remove them just yet until we can establish why they are there as they might be critical to other configurations currently active on the system.
Cheers,
David.
Cheers, David Trad. **When you rate a persons post, you are indicating a thank you or that it helped, but at the same time you are also helping to maintain the community spirit - You don't have to rate posts and you wont be looked down upon :) *
Brandon Turpin
Hi Renato,
Do you have SSL VPN configured?  Those look like the loopback addresses that CCA creates for the virtual-template used for SSL VPN.  CCA used to create a new loopback interface each time you modified the SSL VPN config, but the latest version (3.1.1) has that fixed.
Brandon
Yes I do. I got rid of them anyway, I guess I might run into issues with the existing phones if they're trying to use them. If I run into any issues I'll just put them back.
Hi Renato,
As long as you didn't delete the loopback interface used for the virtual-template that SSLVPN is using, you should be fine.
Brandon
