10-24-2011 10:13 AM - edited 03-21-2019 04:50 AM
Greetings!
My UC560 has several loopback entries, I assume it's CCA's bipolar disorder. Here's an example:
interface Loopback1
ip address 50.50.50.50 255.255.255.0
ip nat inside
ip virtual-reassembly in
interface Loopback2
ip address 51.51.51.51 255.255.255.0
ip nat inside
interface Loopback3
ip address 52.52.52.52 255.255.255.0
ip nat inside
interface Virtual-Template2 type serial
ip unnumbered Loopback1
ip nat inside
interface Virtual-Template3 type serial
ip unnumbered Loopback2
ip nat inside
interface Virtual-Template4 type serial
ip unnumbered Loopback3
ip nat inside
Thoughts? Is it OK to get rid of these?
-Renato
10-24-2011 04:04 PM
Hi Renato,
I have not seen this type of configuration in a very long time...
The UC-560 these days does not use the Loopback setup anymore, it creates a VLAN-90 as a replacement which is a more logical way of doing things in my opinion.
Those Loopbacks look oddly familiar to really old configuration or loopbacks for VPN/VLAN configurations which are additional to the standard configuration.
The current way CCA sets it up is as follows:
interface Vlan90
description $FW_INSIDE$
ip address 10.1.10.2 255.255.255.252
ip access-group 103 in
ip nat inside
And then adds the other associated configuration to go with it.
Was this an upgrade to an older configuration or from scratch?
I would not remove them just yet until we can establish why they are there as they might be critical to other configurations currently active on the system.
Cheers,
David.
10-26-2011 12:13 PM
Hi Renato,
Do you have SSL VPN configured? Those look like the loopback addresses that CCA creates for the virtual-template used for SSL VPN. CCA used to create a new loopback interface each time you modified the SSL VPN config, but the latest version (3.1.1) has that fixed.
Brandon
10-26-2011 12:19 PM
Yes I do. I got rid of them anyway, I guess I might run into issues with the existing phones if they're trying to use them. If I run into any issues I'll just put them back.
10-26-2011 02:26 PM
Hi Renato,
As long as you didn't delete the loopback interface used for the virtual-template that SSLVPN is using, you should be fine.
Brandon
