Get the latest new and information the November issue of the Cisco Small Business Monthly Newsletter
1758
Highlighted
Beginner
UC560 Multiple Sip Trunks
I was reading the feature Description Guide and notice that the UC560 only support one sip trunk. That's mean than i can use only one  voip provider?
Is there  anyway at least  to configure 2 sip trunks?
Please see the atached picture.
Thanks in advance.
Everyone's tags (4)
2 REPLIES 2
Enthusiast
Officially only 1 SIP trunk is supported -- and only 1 trunk is configurable through CCA.
Unofficially, the system is capable of multiple trunks, but this would require CLI changes and would not allow you to receive support from Cisco unless you are UC Express certified.
Beginner
Re: UC560 Multiple Sip Trunks
Hi!
Unfortunately it is currently only one provider through CCA :-( I, like others, we asked or required to support multiple trunk; but nothing moves in this direction that probably require a consisting modification of CCA.
Inside CCO, you can find the documentation for CME version 15.x that lists all the new commands, you can load up to six trunks from the CLI but this definitely breaks the rules of CCA and support SBCS.
I do not know in detail what are the limitations of the implementation, but you can start from this link. This waiting for more info from the CCA team .
73,
Arturo.
