Welcome to the Cisco Small Business Community
Have a question? Click on a topic board below to get started in the community.
Get the latest news in this issue of the Cisco Small Business Monthly Newsletter
510
Highlighted
Beginner
UC560 Outbound Dial Tone
Hello All,
    I am Having trouble setting up our secondary dialtone for a Canadian Client. They are saying it is still the North American dialtone that they are hearing.  We are currently running the following:
CONFIG (Version=8.1)
Version 8.1
Max phoneload sccp version 17
Max dspfarm sccp version 18
Cisco Unified Communications Manager Express
Using CCA 3.0 we have installed the UC500_8.1.0_locale_fr_CA language pack.
I've checked the region settings and everything looks correct to me.
It may be good to note that we just replaced this box a couple weeks ago.  If anyone has any ideas on what I could be missing or could send me in the right direction it would be much appreciated!
    Adam
edit: Attached screen shot of region settings.
3 REPLIES 3
Highlighted
did you changed the cptone under voice-port?
voice-prot x/x/x
cptone CA
- Please rate helpful posts -
Highlighted
Beginner
I haven't tried that yet.
We did change the the Network Local under telephony configurations from U4 (which i believe was user customized or something along those lines).
Sadly I won't be able to test until the morning however, I will definatly give that a look.
Thanks for  the reply!
   Adam S.
Highlighted
Hall of Fame Master
voice-prot x/x/x
cptone CA
That has no effect for outgoing calls (and not even for incoming).
