UC560 overhead paging integration with Bogen TAMB
brandontfrank
Hi - we're cutting over an ancient phone system to a Cisco UC560. They have overhead paging already wired and it terminates into a Bogen TAMB. We plan on running that into an FXO or FXS port.
Can anyone tell me how / what we need to configure on the CCA / CLI side of things to get a dial number associated so when users dial that number it'll activate the overhead paging?
Thanks.
Hi Brandon,
If you set it on FXS you do not need to make any special configurations usually just set a number of the port and that is all.
If you set it to FXO this should be different trunk group for the CCA or just a dial-peer to the specific FXO port in CLI.
You may also take a look at the following link:
https://supportforums.cisco.com/docs/DOC-9776#comment-5481
HTH,
Alex
*Please rate helpful posts
