Welcome to the Cisco Small Business Community
Have a question? Click on a topic board below to get started in the community.
1381
econsystems
Beginner
UC560 Paging line Busy. CME 8.1, CCA3.0
This is a new install of a UC560.  I have setup 1 paging group.  When I dial the paging #, the number keeps coming back busy, After several tries paging connects.  I have all the phones in the staging and absolutely no one is using the feature.
Any suggestions.
5 REPLIES 5
Dan Smith
Beginner
I ran into the same thing on a UC540. instead of messing with it too long I went into CCA and deleted the paging group and re entered it. after that it worked, but not sure what the issue was.
Yep.  That was the first thing I tried.  Some times, have to 6 or 7 tries, before that paging line opens.
We had the same issue on 520.  I just just changed the extension number in CCA saved the config and have not had problem since.
It would be nice to know possible reasons as to why it happens. I have had it happen several times, but it's not worth the troubleshooting if a simple reconfig fixes it.
sviswanatha
Beginner
I have one phone assossiated to a paging number and it was working for some time but now, it is constantly busy. I have removed the paging details using the CCA and then reapply them and still when I call the paging number it is busy all the time.
I am using the following UC540 with CME 8.6 and CCA 3.2(2).
Anybody has any updates on this?
