07-17-2012 03:45 AM - edited 03-21-2019 06:02 AM
Hi there:
My scenario : UC560 connected to 7975 and 7965 ip phones. Here all features are working fine except users are not able to access their phones for personalisation.They canr configure Personnel Address Book, or customized ring tones bcoz of this.
UC560#sh ip int br
Interface IP-Address OK? Method Status Prot ocol
GigabitEthernet0/0 unassigned YES NVRAM up down
In0/0 10.1.10.2 YES TFTP up up
GigabitEthernet0/1/0 unassigned YES unset up down
GigabitEthernet0/1/1 unassigned YES unset up up
GigabitEthernet0/1/2 unassigned YES unset down down
GigabitEthernet0/1/3 unassigned YES unset up up
Vlan1 10.98.64.99 YES NVRAM up up
Vlan5 unassigned YES NVRAM up up
Vlan90 10.1.10.2 YES NVRAM up up
Vlan600 10.98.66.99 YES NVRAM up up
NVI0 unassigned YES unset administratively down down
UC560#sh ip rout
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route, + - replicated route
Gateway of last resort is 10.98.64.70 to network 0.0.0.0
S* 0.0.0.0/0 [1/0] via 10.98.64.70
10.0.0.0/8 is variably subnetted, 9 subnets, 4 masks
C 10.1.10.0/30 is directly connected, Vlan90
S 10.1.10.1/32 is directly connected, Vlan90
L 10.1.10.2/32 is directly connected, Vlan90
S 10.1.10.10/32 is directly connected, Integrated-Service-Engine0/0
S 10.61.0.0/16 [1/0] via 10.98.66.70
C 10.98.64.0/24 is directly connected, Vlan1
L 10.98.64.99/32 is directly connected, Vlan1
C 10.98.66.0/24 is directly connected, Vlan600
L 10.98.66.99/32 is directly connected, Vlan600
running config has attached with this.. Please revert back if anyone cud find the reason.
07-17-2012 08:18 AM
personal speed dial and BLF-speed dial are accesed from services button on the phone
ringtones from settings
doesn't that works for you ?
