Welcome to the Cisco Small Business Community
Have a question? Click on a topic board below to get started in the community.
Get the latest news in this issue of the Cisco Small Business Monthly Newsletter
444
Highlighted
Beginner
UC560 phones can dial out but not in T1 PRI
T1 PRI connection
Confirmed with carrier these settings:
  • T1 line coding = B8ZS
  • T1 framing = ESF
  • Interface switch Type for PRI - National with FAS (User side)
  •   Hunt Type = two way, descending (channel 23 to 1)
  •   Switch Protocol = See ISDN PRI switch-types above
Waiting for call back from SBSC. Any ideas?
1 ACCEPTED SOLUTION
Highlighted
Beginner
Hi Jeremy,
To start whenever you're having call routing issues I always get a debug voice ccapi inout.  If you do that you want to see what dial-peer it is hitting along with the disconnect cause code.
Also, have you setup your Dial-plan incoming?  A common thing i've seen is that the DID numbers you setup in CCA are not exactly as they are sent by the telco. CCAPI can confirm this as well.
Let me know if you need help.
-Trent Good
-Trent Good ** Please rate useful posts! **
3 REPLIES 3
Highlighted
Beginner
Hi Jeremy,
-Trent Good
Highlighted
Beginner
Dial plan from telco was 4 digit DIDs. We had them configured with 10 digits. Thanks Trent
Highlighted
Beginner
Glad to hear it was resolved
