UC560 PRI Channel utilization
jammin_18921
I have a UC560 with a single T1-PRI and I am wanting to know if the UC series has any monitoring tools so that I can actively monitor their PRI utilization.  We believe that thier call flow is more than they expected but I am unable to find a way to monitor this on my side. Any help would be appreciated.
David Trad
Hi James,
The only thing I can suggest is to use SNMP and capture the call traps, you can use a free and open source application such as FAN "Fully Automated Nagios" which can show you the call rate per minute/hour/day.
Consider looking at that
Cheers,
David Trad.
Cheers, David Trad. **When you rate a persons post, you are indicating a thank you or that it helped, but at the same time you are also helping to maintain the community spirit - You don't have to rate posts and you wont be looked down upon :) *
