Please be advised, the GuideMe Wizard is no longer available on the Small Business Support Community. For search capability please use the community search field to find content related to Cisco Small Business documents, videos, and discussions.
436
Beginner
UC560 SIP Configuration via CCA
We are trying to configure SIP trunks VIA CCA (Latest version) on a UC560 latest version.
However the username and password field doesn't save.  When you open CCA SIP trunk configuration the fields are blank, fill them in and save, exist and go back in they are still blank.  If you ftp the config off the unit and search for the field "username" only the phones and admins come up - no mention of SIP.
Are we missing something?
Everyone's tags (1)
2 REPLIES 2
Hello,This sounds like you
This sounds like you may have Windows firewall or Anti-virus software running. Also make sure you are using Windows 7 or XP. Windows 8 will not work properly with CCA.
Also if you are using SSL VPN, make sure that only version Anyconnect 2.5.6005 is loaded on the UC. Anything higher will use up the memory and you will not be able to write to the config.
I hope this helps.
Chris
Beginner
It turned out to be password
It turned out to be password length, any password longer than 8 digits won't save.
