UC560 SP525G CallerID and Name
mindmaster
is there a way that the SPA525G shows the Name of the Caller if its number is in an addressbook.
MayBe with XML app, i know it works with CUCM and 79XX phones but i there any equal for the UC?
THANKS
HSS
5 Replies 5
Steven DiStefano
For internal callers, mine (configured with CCA) does it out of the box... (if thats what you mean?)
Its a bit blurry, but it says "From Five Zerofour" and under that it says "211" <-- the extension of the calling party, which is also monitored by this phone on button two (hence the red there)...
Internal works fine.
i mean external callers.
If calling name is not provided by the PSTN for inbound calls, we cannot display it.
Marcos
Can the phone post the incoming calling number to a XML/website?
Can i remote push the informations to the Phonedisplay?
thanks
HSS
No, this is not possible.
Marcos
