Can you use the PRI on the UC560 & the SR520 T-1 at same time (essentially have 2 PRIs) and is it manageable thru CCA?
Solved! Go to Solution.
The UC500 series only supports T1 circuits provisioned for PRI. The SR520-T1 router only supports circuits provisioned for data. You can have your UC560 configured to use a PRI attached to that device and also use a data T1 on the SR520 at the same time. Both of which are configurable via CCA.
Cole
Cole
Somehow I was under impression that SR520 supported PRIs. Thanks
Can you add second PRI card on UC560?
Yep.
