Welcome to the Cisco Small Business Community
Have a question? Click on a topic board below to get started in the community.
Get the latest news in this issue of the Cisco Small Business Monthly Newsletter
923
Highlighted
Beginner
UC560 Telmex E1 DID mappings
I installed a UC560 around Dec/2011 with an E1 trunk provided by Telmex (Mexico's incumbent Operator). I followed the manual instructions to get it up and running. All went fine until I had to start mapping the DIDs to extensions via the CCA (3.1). CCA ommits the "direct-inward-dial" command and shuts down the created dial-peer.
Thanks to a local Cisco resource, we found the problem and a simple workaround; first create the mapping with CCA and then in CLI:
# dial-peer voice XXXX pots
# no shutdown
# direct-inward-dial
Where XXXX is the label that the CCA created for the mapping.
I tried to add another DID map with CCA 3.2, but the bug is still there. Does anyone know if this will ever be fixed?
Pedro.
0 REPLIES 0
