Welcome to the Cisco Small Business Community
Have a question? Click on a topic board below to get started in the community.
481
Frank Hoeben
Beginner
UC560 translation pattern on pots voodoo required
One of my clients has an 'interesting' problem that probably can be solved with a translation pattern on the right dial-peer.
I have tried a bit myself but obviously without the desired result.
Let my describe the situation.
1 - Device 1 - old analog box - receives a call
2 - Device 1 signals some software via RS232 that it is receiving a call
3 - Device 1 opens an analog line on a second analog port and dials (DTMF) an external voice number
4 - Device 2 - a generic PBX - receives the call from Device one, opens an external line and calls out
5 - Device 3 - a Cisco UC560 receives the external call and puts it through to the internal designated line
The desire: eliminate the PBX and connect Device 1 directly to the UC560.
Problem 1: Device 1 cannot be programmed anymore, software and instructions have been lost.
Problem 2: Device 1 dials an external number (without a prefix).
Is there a way to keep the call on the UC560 without making a u-turn call back in?
0 REPLIES 0
