UC560 with UCCX 9.0
raquiros
Beginner
Beginner
Greetings everyone...
I need to know if the UC560 is compatible with UCCX 9.0....
It seems like UCCX 9.0 works with CME, so I think it should work...
I need to be totally sure before buying it, so I would please appreciate if someone know this or has documentation about it.
Thanks in advance!
Rafael Quiros iSynerG
paolo bevilacqua
Hall of Fame Master Hall of Fame Master
Hall of Fame Master
If I was you, I would not buy it, because you may be running unsupported configuration, then you would have no recourse if something doesn't work.
Small call center features of UC500 / CME already do a lot, I'd try to stick with them for as much as passible, and if not, use ISR G2 router tor CME.
I found this from the documentation about the Cisco Unified Contact Center Express 7.0.
I hope it helps everyone looking for help on UCCX integration with the UC500 Series...
Just as an update, I ended up with a Cisco 2951/CME with IPCC Express on an external MCS-7816.
Rafael Quiros
iSynerG
