Unable to dial extension in hunt group - UC540
IntersumLtd
I am having an issue with configuration of hunt groups can the [strike]Borg[/strike] Board help me?
I have a new UC540 and have configured a hunt group with 2 members and associated extensions (2 just now - more to follow) - the users and extensions are in the group.  When dialling the primary extension internally, it does not connect - audible busy tones.
There is a soft key on the handset for logging in and out of the hunt group  - both phones display this
Hunt group extension = 234
3 phones configured - 302, 230, 240
302  and 240 are in hunt group
All phones can call each other
I used Cisco Config Assistant and Config Wizard to set it up
Here is the config:
ephone-hunt 1 peer
pilot 234
list 302, 240
final 888
timeout 8, 8
no-reg pilot
statistics collect
description Helpdesk
ephone  5
device-security-mode none
mac-address 1CDF.0F4A.9802
ephone-template 16
max-calls-per-button 2
username "user1" password 123456
type 502G
button  1:296
ephone  6
mac-address 1CDF.0F4A.980A
ephone-template 16
username "user2" password 123456
type 502G
button  1:297
ephone  7
mac-address 1CDF.0F4A.9813
ephone-template 16
username "user3" password 123456
type 502G
button  1:39
UC_540#sh ephone-hunt
Group 1
    type: peer
    pilot number: 234, peer-tag 20041
    list of numbers:
        302, aux-number A234A0000, # peers 1, logout 0, down 0
            peer-tag  dn-tag  rna  login/logout  up/down
             [20040     296    0       login      up  ]
        240, aux-number A234A0001, # peers 1, logout 0, down 0
             [20042     297    0       login      up  ]
    final number: 888
    preference: 0
    preference (sec): 7
    timeout: 8, 8
    description: Helpdesk
    hops: 2
    next-to-pick: 2
    E.164 register: no pilot
    auto logout: no
    stat collect: yes
    callqueue display: continuously
    debug: no
Any thoughts please?
bethingt
IS 302 and analog line? What type of role is setup for that FXS Port?
Brian
302 is the extension - the pilot number for the group internally is 234
FX0/1/0 and 0/1/1 are set to trunk - they will go to the exisiting BT lines when we swap out the existing kit for the UC540
Cheers
I think what brian is asking is the FXS extension (302) operation mode.
Is it User Mode, COmmon Area, or FAX?
This was resolved by using the no ephone-hunt login command
Thanks for assisting
