Welcome to the Cisco Small Business Community
Have a question? Click on a topic board below to get started in the community.
676
crystalcross
Beginner
Unable to make outbound calls
When trying to make an outbound call I dail "9" then the number and nothing happens the call doesn't go through (the phone just goes back to the main screen). I placed an analog phone on the line and made a call (did not dial "9")  and the call went through like a charm.  I don't know what the problem could be or why the system will not allow calls to be made, calls coming into the system work just fine.
1 ACCEPTED SOLUTION
Christopher Edgeworth
Frequent Contributor
It is hard to tell what is happening without looking at your system.  Suggest making a call to the Cisco Small Business Support Center.
Chris
2 REPLIES 2
Chris
crystalcross
Beginner
Through the help of the Business Support we were able to determine the pronblem had to do with the line voltage. At the time the line voltage was -48v it was then suggested by the carrier to switch the tip and ring on the 66 block to reverse the voltage. We were able to do this and the voltage became positive and calls were able to go out.
