Welcome to the Cisco Small Business Community
Have a question? Click on a topic board below to get started in the community.
1682
Jeremy Koch
Beginner
Update 9971 with CCA3.2.1 - how?
Hi, can nayone please tell me how to update a CP-9971 SIP phone with CCA 3.2.1? i have the phoneloads, but CCA wont accept them...
UC540 system with 8.6 Software Pack
UC540 system with 8.6.2 Software Pack
1 ACCEPTED SOLUTION
bkwon
CCA3.2.1 support 9971 phone load upgrade through SWP only for now, if you want to upgrade FW that not in the SWP and then should be a manual way.
example of 9-2-2
1. copy the phoneloads to flash/phones/9971
2. add tftp-server
tftp-server flash:/phones/9971/dkern9971.100609R2-9-2-2.sebn alias dkern9971.100609R2-9-2-2.sebn
tftp-server flash:/phones/9971/kern9971.9-2-2.sebn alias kern9971.9-2-2.sebn
tftp-server flash:/phones/9971/rootfs9971.9-2-2.sebn alias rootfs9971.9-2-2.sebn
tftp-server flash:/phones/9971/sboot9971.031610R1-9-2-2.sebn alias sboot9971.031610R1-9-2-2.sebn
tftp-server flash:/phones/9971/sip9971.9-2-2.loads alias sip9971.9-2-2.loads
tftp-server flash:/phones/9971/skern9971.022809R2-9-2-2.sebn alias skern9971.022809R2-9-2-2.sebn
3.
voice register global
load 9971 sip9971.9-2-2
create profile
4.
Reset the phone
9 REPLIES 9
bkwon
example of 9-2-2
2. add tftp-server
3.
create profile
4.
Reset the phone
Jeremy Koch
Beginner
Ok i think i worked it out for now.... when i upgraded my UC540 to 8.6 i didnt have the 9971 so the phone load wasnt selected. i am now just adding the phone load by getting CCA to look back at the UC540_8.6 upgrade pack and install the phoneload that way....
looks to be working, will report back soon!
Hi ok so i have gotten the new 9971 phoneload on the uC box...however i have rebooted the 9971, i have reset it, i have even deleted the phone/extension and recreated it but i still cante get it to upgrade?
what could i be doing wrong?
please do 'debug tftp packets/event' to see what is going on.
and can i have show run regarding above steps.
thanks
Syslog logging: enabled (0 messages dropped, 3 messages rate-limited, 0 flushes, 0 overruns, xml disabled, filtering disabled)
No Active Message Discriminator.
No Inactive Message Discriminator.
Console logging: disabled
Monitor logging: disabled
Buffer logging: level debugging, 4 messages logged, xml disabled,
filtering disabled
Exception Logging: size (4096 bytes)
Count and timestamp logging messages: disabled
Persistent logging: disabled
No active filter modules.
Trap logging: level informational, 193 message lines logged
Logging Source-Interface: VRF Name:
Log Buffer (5000000 bytes):
000197: Jul 6 09:36:08.063: %SYS-5-CONFIG_I: Configured from http by cisco on 192.168.1.24
000198: Jul 6 09:36:25.363: %SYS-5-CONFIG_I: Configured from console by cisco on vty3 (192.168.1.24)
000199: Jul 6 09:36:26.583: VOICE REGISTER POOL-2 has unregistered. Name:SEP2893FEA305DE IP:10.1.1.11 DeviceType:Phone
000200: Jul 6 09:37:00.859: VOICE REGISTER POOL-2 has registered. Name:SEP2893FEA305DE IP:10.1.1.11 DeviceType:Phone
please do
debug tftp event
debug tftp packet
and reset the 9971 phone.
undebug all
send me the show log and show run. after remove any private.
thanks
Buffer logging: level debugging, 50 messages logged, xml disabled,
filtering disabled
Trap logging: level informational, 285 message lines logged
000287: Jul 6 11:48:24.875: %SYS-5-CONFIG_I: Configured from http by cisco on 192.168.1.24
000288: Jul 6 11:48:25.099: %SYS-5-CONFIG_I: Configured from http by cisco on 192.168.1.24
000289: Jul 6 11:48:25.319: %SYS-5-CONFIG_I: Configured from http by cisco on 192.168.1.24
000290: Jul 6 11:48:25.363: %SYS-5-CONFIG_I: Configured from http by cisco on 192.168.1.24
000291: Jul 6 11:48:25.399: %SYS-5-CONFIG_I: Configured from http by cisco on 192.168.1.24
000292: Jul 6 11:48:25.487: %SYS-5-CONFIG_I: Configured from http by cisco on 192.168.1.24
000293: Jul 6 11:49:23.383: TFTP: Server request for port 49152, socket_id 0x8B05464C for process 185
000294: Jul 6 11:49:23.383: TFTP: read request from host 10.1.1.21(49152) via BVI100
000295: Jul 6 11:49:23.383: TFTP: Looking for CTLSEP2893FEA305DE.tlv
000296: Jul 6 11:49:23.383: TFTP: Sending error 1 No such file
000297: Jul 6 11:49:23.503: TFTP: Server request for port 49152, socket_id 0x8B05464C for process 185
000298: Jul 6 11:49:23.503: TFTP: read request from host 10.1.1.21(49152) via BVI100
000299: Jul 6 11:49:23.503: TFTP: Looking for SEP2893FEA305DE.cnf.xml
000300: Jul 6 11:49:23.503: TFTP: Opened flash:/SEP2893FEA305DE.cnf.xml, fd 14, size 4326 for process 185
000301: Jul 6 11:49:23.507: TFTP: Sending block 1 (retry 0), socket_id 0x8B05464C
000302: Jul 6 11:49:23.511: TFTP: Received ACK for block 1, socket_id 0x8B05464C
000303: Jul 6 11:49:23.511: TFTP: Sending block 2 (retry 0), socket_id 0x8B05464C
000304: Jul 6 11:49:23.511: TFTP: Received ACK for block 2, socket_id 0x8B05464C
000305: Jul 6 11:49:23.511: TFTP: Sending block 3 (retry 0), socket_id 0x8B05464C
000306: Jul 6 11:49:23.515: TFTP: Received ACK for block 3, socket_id 0x8B05464C
000307: Jul 6 11:49:23.515: TFTP: Sending block 4 (retry 0), socket_id 0x8B05464C
000308: Jul 6 11:49:23.519: TFTP: Received ACK for block 4, socket_id 0x8B05464C
000309: Jul 6 11:49:23.519: TFTP: Sending block 5 (retry 0), socket_id 0x8B05464C
000310: Jul 6 11:49:23.519: TFTP: Received ACK for block 5, socket_id 0x8B05464C
000311: Jul 6 11:49:23.519: TFTP: Sending block 6 (retry 0), socket_id 0x8B05464C
000312: Jul 6 11:49:23.523: TFTP: Received ACK for block 6, socket_id 0x8B05464C
000313: Jul 6 11:49:23.523: TFTP: Sending block 7 (retry 0), socket_id 0x8B05464C
000314: Jul 6 11:49:23.523: TFTP: Received ACK for block 7, socket_id 0x8B05464C
000315: Jul 6 11:49:23.523: TFTP: Sending block 8 (retry 0), socket_id 0x8B05464C
000316: Jul 6 11:49:23.527: TFTP: Received ACK for block 8, socket_id 0x8B05464C
000317: Jul 6 11:49:23.531: TFTP: Sending block 9 (retry 0), socket_id 0x8B05464C
000318: Jul 6 11:49:23.539: TFTP: Received ACK for block 9, socket_id 0x8B05464C
000319: Jul 6 11:49:23.539: TFTP: Finished flash:/SEP2893FEA305DE.cnf.xml, time 00:00:00 for process 185
000320: Jul 6 11:49:30.527: TFTP: Server request for port 49152, socket_id 0x87A3C3C4 for process 185
000321: Jul 6 11:49:30.527: TFTP: read request from host 10.1.1.21(49152) via BVI100
000322: Jul 6 11:49:30.527: TFTP: Looking for English_United_States/gd-sip.jar
000323: Jul 6 11:49:30.527: TFTP: Sending error 1 No such file
000324: Jul 6 11:49:30.975: TFTP: Server request for port 49152, socket_id 0x87A3C3C4 for process 185
000325: Jul 6 11:49:30.975: TFTP: read request from host 10.1.1.21(49152) via BVI100
000326: Jul 6 11:49:30.975: TFTP: Looking for United_States/g4-tones.xml
000327: Jul 6 11:49:30.975: TFTP: Sending error 1 No such file
000328: Jul 6 11:49:31.051: TFTP: Server request for port 49152, socket_id 0x87A3C3C4 for process 185
000329: Jul 6 11:49:31.051: TFTP: read request from host 10.1.1.21(49152) via BVI100
000330: Jul 6 11:49:31.051: TFTP: Looking for featurePolicyDefault.xml
000331: Jul 6 11:49:31.055: TFTP: Opened flash:/featurePolicyDefault.xml, fd 14, size 825 for process 185
000332: Jul 6 11:49:31.055: TFTP: Sending block 1 (retry 0), socket_id 0x87A3C3C4
000333: Jul 6 11:49:31.063: TFTP: Received ACK for block 1, socket_id 0x87A3C3C4
000334: Jul 6 11:49:31.063: TFTP: Sending block 2 (retry 0), socket_id 0x87A3C3C4
000335: Jul 6 11:49:31.067: TFTP: Received ACK for block 2, socket_id 0x87A3C3C4
000336: Jul 6 11:49:31.067: TFTP: Finished flash:/featurePolicyDefault.xml, time 00:00:00 for process 185
Jeremy Koch
Beginner
Ok, i have managed to get it to update. i changed my machine running CCA to a laptop with a direct connection to the uc540 and it all worked fine as you would expect. just dragged the file onto the UC_540 and it uploaded.
the 9971 then updated after i rebooted it.
no onto my next problem of some missing .jar files for the SIP 9971...
almost there...
could you please provide more detail about your new issue, when it happened, what is error message etc.
thanks
