UPM Licensing Bundled with BE6000 - 9.0
clayostlund
Contributor
Contributor
    The guide states:
Provisioning Manager Licensing
The license file is part of the OVA image. This file allows you to manage:
  • 1500 phones or voice terminals
  • One Cisco Unified Communications Manager
  • One Cisco Unity Connection
  • One Cisco Unified IM and Presence
  • 30 total ‘pmadmin’ and Self-Care user logins
We will require the ability to managed more than 1 CUCM, CUC, and CUP.  Shoretel totes this as a disadvantage towards Cisco, so allowing the UPM to manage from a single spot all applications/nodes is important.  Need the ability to have at Least 1 Publisher and Subscriber for each of the above.
sbommaji
Beginner
Beginner
Clay,
Clustering for redundancy and load balancing is not supported as you already know.  However I like your suggestion about provisioning multiple Applications (for example CUCM for redundancy or for stagging in a lab environment). I will reach out to UPM PM to see if this is architecturally possible and if we got it on our roadmap.
Sunil Bommaji
