Please be advised, the GuideMe Wizard is no longer available on the Small Business Support Community. For search capability please use the community search field to find content related to Cisco Small Business documents, videos, and discussions.
933
Highlighted
Beginner
using CCA to configure Multisite - uc540 at two sites
                  Used CCA 3.2.1 multisite Mgr  -  Each site has a unique Vlan subnet, can ping WAN IP on both sites...but can't ping the data vlan on either site. Therfore, can't make intersite calls. what should I be looking for ? not sure if all of the access lists were created via CCA?
Everyone's tags (3)
2 REPLIES 2
Hello Don,
Do you see if the link between the sites is up?
Best regards,
Alex
there is no other router etc between 2 uc540 (VPN terminationpoint is uc540) right?
and it looks there is no FW enable in both uc540, is this your intention ?
please provide 'show cry detail' from sites.
