Welcome to the Cisco Small Business Community
Have a question? Click on a topic board below to get started in the community.
Get the latest news in this issue of the Cisco Small Business Monthly Newsletter
740
Highlighted
Beginner
Using speed dial button as paging on provisioned 525g's
Hello everyone!
We recently switched to a hosted phone provider with provisoning for our 2 SPA525G2's but still want to maintain an internal paging function between them using a speed dial button. For less confusion, lets call in ex5.
I have successfully created a dial plan and am able to dial *96 + extension number to activate the paging system. My objective is to just hit ex5 and having it automatically activate the paging function.
I feel I'm very close but need help with the last step.
Please help!
Everyone's tags (4)
6 REPLIES 6
Highlighted
Frequent Contributor
put in the dial plan <5:*965>
Highlighted
Beginner
Thanks for your response!
Question, wouldn't that use my provisioned phone system still? How could I directly dial the LAN side IP?
I currently have (<5:5@192.168.0.104:5060>S0|xx.<:@192.168.0.104:5061>) which allows me to call the other phone but not page it.
Highlighted
Oops, I didn't see "internal" aspect.
To direct dial, you'd have to do what you did.
Since you are already using 5 for direct dial, maybe you can substitute another digit.  Like <3:*965@192.168.0.104>
Highlighted
Beginner
Feels like we are getting close but I'm still getting an invalid number error when I dial it.
Highlighted
Beginner
Re: Using speed dial button as paging on provisioned 525g's
Sorry for resurrecting a dead thread, but I still have the same question, which wasn't answered here, and I couldn't find anything here or in Google:
How can I put the SPA525G2's internal LAN-based paging function (the one that *96 invokes by default invokes) on a phone or attendant call button?
As the OP was trying to get across, just using "fnc=sd;ext=*96123@$PROXY" (or without "@$PROXY") sends a dial command to my VoIP provider; it does not invoke the Cisco internal extension paging function.
Interestingly enough, if I have a group page defined (I'm using the default group "800"), this command does work:  "fnc=sd;ext=800".  But group pages are of limited utility because of the many limitations.
Thanks.
...R
Everyone's tags (2)
Highlighted
Beginner
Doesn't it always work this way... I've fought this for 4 hours. I posted my query here as a last resort, and then I thought, "I wonder what would happen if I used "*96#123" instead of just "*96123..."
The answer is, it works.  I'll leave this up hopefully to save someone the 4 hours.
