10-02-2012 09:56 AM - edited 03-21-2019 06:22 AM
I started the deployment of our BE6K - 9.0, deployed CUC, UCM, CUP, UPM, and had no issue with pre-loaded images, ova's, etc.
I'm trying to deploy the OVA for VCS, however it fails with the following error:
I have re-downloaded the OVA off the local datastore on the C220 to make sure my copy didn't cause an issue. Tried from two different machines with the same Result. It appears as though the VCS-C image i was shipped is Corrupt.
If this were a production system install, what are my steps at aquring proper install media to fix this issue?
Also, for this Trial, I'll need a new .ova to give VCS a load.
10-02-2012 01:46 PM
Will have someone reach out to you immediately on this one.
Sunil
10-02-2012 08:40 PM
Clay,
I have uploaded the VCS .ova file on the File Exchange Server -
https://upload.cisco.com/cgi-bin/swc/fileexg/main.cgi?CONTYPES=BE6000_EFT
Please download the file and let us know about the VCS deployment. If you still see the issue, could you please provide the steps you are following to deploy the .ova file.
Nitin.
10-02-2012 09:06 PM
The upload fixed the issue, the OVA deployed successfully. Thanks.
10-03-2012 08:21 AM
Clay,
Thanks for the update.
Nitin.
