I'm confused by the title of the thread, but I can answer your question.
If you want to change the DNS information that the devices on the network are receiving go top the following in CCA:
Configure>Routing>DHCP Server
Select the DHCP pool that the devices are getting IP address from and click Modify. In here you can set a Primary and Secondary DNS server.
Adam Compton
