VPN with certificate instead of preshared key
danielblock1
I have set up a vpn through CCA that uses a pre-shared key and it works great. I was just wondering if the UC520 can handle a certificate instead? If so, are there any instructions on how to do it? Also, I know that CME doesn't have much support for active directory, but can the VPN authenticate against Active Directory?
Dan
Steven Smith
Level 7
Level 7
This depends if you are wanting to use CCA or not.  If you want to use CCA, this is not possible today.
You can use radius today to authenticate users for ezvpn.
There is a large amount of information in this link, but I think it will answer your questions.
http://www.cisco.com/en/US/docs/ios/12_2t/12_2t8/feature/guide/ftunity.html
