06-05-2013 11:15 PM - last edited on 03-25-2019 11:05 PM by ciscomoderator
Dear support,
If i have installed a BE 6000 and have already Linksys Wireless Access Points, can i purchase wireless phones and use them with those WAP?
Thank you
06-10-2013 05:03 AM
Kind reminder
06-10-2013 08:20 AM
Mireille,
The 792X (7925/7926) phone wifi phones are supported with the 6K. You are free to use them with any access points and protocols that are supported with the 792x phones. However note that Access points used will bear upon the reliability of the phones. The better enterprise grade access points you use with better roaming features, the better your call qulaity will be. With linksys, if they are consumer access points, you are going to get what you pay for.
Navin Albert
