Get the latest Cisco news in this December issue of the Cisco Small Business Monthly Newsletter
868
When registrar on sip-ua trunk is activated, another dial-peer stops working.
Hi forum members
I have the following scenario:
SIP PBX  <--> UC540 <--> SIP trunk to service provider.
The UC540 has the phones with numbers 100 to 105 registered. The PBX has the 7XX numbers. To the PBX, the following dial-peer is used:
dial-peer voice 2 voip
 description To MX-ONE
 destination-pattern [2-7]..$
 session protocol sipv2
 session target ipv4:10.30.0.2
 voice-class codec 1
 dtmf-relay sip-notify
dial-peer voice 1 voip
 description incoming from MX-ONE
 incoming called-number 10.
 voice-class codec 1
voice class codec 1
 codec preference 1 g711ulaw
 codec preference 2 g729r8
Everything works for this dial-peer, until the ITSP SIP trunk, with the following configuration, goes up:
sip-ua
 credentials username xxxxxx password 7 xxxxxxxx realm sip.elitevoip.net
 authentication username xxxxxxxx password 7 xxxxxxx
 sip-server ipv4:5.39.84.82
 host-registrar
dial-peer voice 7 voip
 description Internacional via SIP Trunk
 translation-profile outgoing PSTN-OUT-INTERNACIONAL
 destination-pattern 00.T
 session target sip-server
voice translation-profile PSTN-OUT-INTERNACIONAL
 translate calling 3
 translate called 5
voice translation-rule 3
 rule 1 /^100/ /226434580/
 rule 2 /^101/ /226434581/
 rule 3 /^102/ /226434582/
 rule 4 /^103/ /226434583/
 rule 5 /^104/ /226434584/
 rule 6 /^105/ /226434585/
voice translation-rule 5
 rule 1 /^00/ //
Everything works perfect with the ITSP SIP trunk. It registers, and calls go out an in with no problems:
CMELDA001#sh sip-ua register status
Line                             peer       expires(sec) registered P-Associ-URI
7143167791                       -1         2834         yes
P.S.: the ephone-dn numbers are already with "no-reg" option, just to isolate them from registering in the sip-ua trunk.
THE PROBLEM is: when this sip-ua trunk goes up, I cant receive calls from the PBX. The call is placed, the phone on the UC540 rings, I answer but it continues ringing on the originating phone up to 20 seconds.
It starts when I put the "registrar" command. Issuing the "no registrar" under the sip-ua, I start receiving calls again from the PBX.
Do someone had a similar problem? I am attaching the debugs with the sip registrar (not working) and without (working).
Thanks all
Everyone's tags (3)
