02-01-2012 06:58 AM - edited 03-21-2019 05:17 AM
All the SPA525G and SPA525G2 handsets we support on UC500s are showing the date as the 02/02/2012.Including our own!
None have an NTP server set, so they shouldn't be getting incorrect time data from anywhere.
SPA524s and SPA509s on the same systems seem fine.
The actual UC500s (mix of UC520 and 540s) have the correct date on them.
Any ideas?
Adam
02-06-2012 12:49 AM
Same problem here ... any fix available ?
02-06-2012 06:14 AM
I can understand (maybe) waiting for almost a week for a fix. However, lack of a suggestion for a suitable work-around is inexcusable when customers are complaining and Cisco "partners" are hanging.
02-06-2012 06:35 AM
There is a beta patch they made available to me and that seemed to fix it. It was emailed over the weekend, Saturday to be exact.
02-06-2012 06:38 AM
OK Cisco, where can we get ahold of this Beta firmware. If I get another call from another client complaining about this, I am going to Nortel.
02-06-2012 06:43 AM
We now have a patch available to address this. There are images based on 7.4.8 and 7.4.9c plus the patch. I've tested them to confirm they're working. For now, please open a case with SBSC so we can publish the images for you while we're working on getting the images published publically.
Brandon
02-06-2012 02:36 PM
One of our customers also experienced this issue. I opened a case with Cisco SBSC and was given the spa525g-7-4-9c-p02 firmware. SBSC advised that this is beta firmware and reported that no release date for the full version of firmware is available. We're hesitant to move our customer to beta firmware so we're going to hold off for now.
One interesting thing is my own SPA525G which is running 7.4.9c but using straight SIP (not connected to a UC) has the correct time.
02-06-2012 07:39 PM
Yes, the bug is only apparent when using SCCP.
02-07-2012 11:51 AM
Hi Ryan,
I wanted to clarify that the firmware you were given is the full firmware version and is not beta. The patch files are 7.4.8/7.4.9c + the fix, so they should be fine to use.
Also, my understanding is that if a valid NTP server is set on the phone in SIP mode, the correct date is shown. Do you have an NTP server set on your SPA525G using SIP?
Brandon
02-07-2012 02:04 PM
Brandon,
Can you provide additional details on the fixed firmware? I specifically asked the SBSC tech if the this was official release-ready firmware and was informed that it was not. If this is full, release-ready firmware, then why is it not being posted publicly as a new release? Can you provide an ETA on when this will be official?
We also had another customer complain of this issue today.
02-08-2012 07:49 AM
Hey Brandon, forgive me, but I'm not clear on the how to acquire the patch files you described. Can you give a bit more information.
Chris
02-08-2012 07:51 AM
You just need to open a case with Cisco Small Business Support and refer to the Bug #CSCtx71387.
http://www.cisco.com/en/US/support/tsd_cisco_small_business_support_center_contacts.html
I usually just start a chat session from the above link.
02-07-2012 01:41 AM
The only temporary fix we can offer our customers is to roll back the UC by 1 day, this displays the correct date on the 525 handsets however break any reliance on schedules etc as the UC has the incorrect date.
On March 1st (When this apparently will not be a problem) we will have to roll forward again.
03-01-2012 07:14 AM
For what it's worth, our 525G phones showed 3/1/12 all day yesterday, 2/29/12. This was the first day we noticed the problem. The 504G phones we have showed the correct date, 2/29.
Today, all phones display 3/1. Phone call logs misidentify yesterday's calls as 3/1 however on 525G phones.
We did not apply any firmware patches or advance the system date.
