883
Highlighted
wip310: problema con tftp ringtone
intento enviar un tono vía tftp con la siguiente
sintaxis:
http://10.100.40.123/ringtone1?tftp://10.100.40.2/tonos/alarma1.mid
y obtengo el resultado "failed":
Las rutas de origen y destino son correctas.
He probado a poner en EXT1 Line enable "NO" para hacer el tftp
El firmware es 5.0.13(04261322)
4 REPLIES 4
Highlighted
¿Alguna respuesta?
Highlighted
I translate the problem........
I try to send a ringtone via tftp with the following syntax:
1st Image
and get the result "failed"
2nd Image
the paths are correct.
I tried to put in EXT1 -> LINE ENABLE "no" to make the tftp.
The firmware is 5.0.13 (04261322)
Highlighted
Trying to have an answer moving to
this place
Highlighted
Hello Javier,
can you check if you have any firewall or antivirus that is blocking the tftp to have connections on you operative system?
You could try with the tool I've attached
Mauro
