We are starting to deploy some of these phones behind IPitomy (Asterisk) systems. I have a couple of questions about configuring them.
1. I have entered my Multicast address 224.168.168.168:6535 into the phone, I update the config, and when I dial the acces number to start the page I get disconnected. Any ideas why this would happen?
2. Is there any way to "Save" this config once I get it setup on one phone?
The multicast address parameter is only for use with the spa9000 as the proxy.
If you want to save the existing config, you can send a SIP Notify - Report to the phone and be sure to populate the Report Rule parameter with the location where you want the file to be sent to.
