XML Directory - SPA50x - incoming call
Scorfly56
Is there a way to get the name displayed one the screen while I get an Incoming call ?
<CiscoIPPhoneDirectory>
     <Title>Aucune</Title>
     <DirectoryEntry>
          <Name>My Name</Name>
          <Telephone>0631xxxxxx</Telephone>
     </DirectoryEntry>
     <DirectoryEntry>
          <Name>BadGuy</Name>
          <Telephone>0972xxxxxx</Telephone>
     </DirectoryEntry>
</CiscoIPPhoneDirectory>
I saw the possibilities with the "Personal Directory", but it's too limited, that's why I would like to do it with the XML Directory
Does somebody have a solution for me ?
Thx, Louis
paolo bevilacqua
Wrong forum, post in "small business voice - SPA phones". You can move your post using the actions panel on the right.
Thx, i moved the subject in the good forum (I think)
I'm lost in this website ...
I hope that somebody could help me with my request !
Dan Lukes
The preferred solution - the name should be delivered together with callers number by your's local exchange. If not possible, then personal directory can be used. Unfortunatelly, XML Directory can't be used for such task as far as I know. May be LDAP server may help, but I have no experience with it.
Althougth it's not answer your original question, you may consider somewhat helpful the following document:
Note that the reference to document mentioned in previous comment has been lost during Jive->Drupal migration of CSC system. Unfortunately, I don't remember what document I mentioned two years ago ...
