cancelar
Mostrar resultados para
Pesquisar em vez de
Queria dizer:
Apresentações
Útil
Respostas
Falha de conectividade entre 2951 ISR e o PSTN E1 ISDN PRI
tekknova2008
Boas.
Tentei o dia todo sem sucesso conectar o 2951 atraves de uma interface E1 numa VWIC3-1MFT ao nosso PSTN.
Depois de ter configurado o card type e a controladora, a luz AL da interface acende amarelo o que representa um "Transmitter is sending remote alarm."
Aqui usamos o modelo Europeu de signaling etc. Alguma ideia?
   show controllers E1
E1 0/0/0 is down.
  Applique type is Channelized E1 - balanced
  Receiver has loss of signal.
  alarm-trigger is not set
  Version info FPGA Rev: 08121917, FPGA Type: PRK1
  Framing is CRC4, Line Code is HDB3, Clock Source is Line.
  International Bit: 1, National Bits: 11111
  Data in current interval (243 seconds elapsed):
     0 Line Code Violations, 0 Path Code Violations
     0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
     0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 243 Unavail Secs
  Total Data (last 12 15 minute intervals):
     2 Line Code Violations, 0 Path Code Violations,
     0 Slip Secs, 0 Fr Loss Secs, 1 Line Err Secs, 0 Degraded Mins,
     0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 10800 Unavail Secs
CME_Router#show isdn st
CME_Router#show isdn status
Global ISDN Switchtype = primary-net5
ISDN Serial0/0/0:15 interface
        dsl 0, interface ISDN Switchtype = primary-net5
    Layer 1 Status:
        DEACTIVATED
    Layer 2 Status:
        TEI = 0, Ces = 1, SAPI = 0, State = TEI_ASSIGNED
    Layer 3 Status:
        0 Active Layer 3 Call(s)
    Active dsl 0 CCBs = 0
    The Free Channel Mask:  0x00000000
    Number of L2 Discards = 0, L2 Session ID = 0
    Total Allocated ISDN CCBs = 0
CME_Router#show run
card type e1 0 0
logging buffered 51200 warnings
no aaa new-model
clock timezone Maputo 2 0
network-clock-participate wic 0
isdn switch-type primary-net5
voice-card 0
codec complexity medium
controller E1 0/0/0
pri-group timeslots 1-31
3 RESPOSTAS 3
Bruno Rangel
Mario Boa Tarde
Primeiramente verifique sua conexão de Layer 1.
Cabo está conectado corretamente ou se os cabos estão em boas condiçoes, verifique também se a sua interface não esta administrativamente down, se não reinicialize a interface atraves do comando shutdown e depois no shutdown.
Sua conexão de Layer 2 deve ficar no stado de MULTIPLE_FRAME_ESTABLISHED.
Cheers
Bruno Rangel
Please remember to rate helpful responses using the star bellow and identify helpful or correct answers
Bruno,
Obrigado pela resposta.
Hoje de manhã ( como teste ) tirei da configuração da controladora o framming crc4 e resolveu-me o problema. Pelo menos até agora está em cima.
Valeu!
Abrc
Muito Bom Mario
Pode-se considerar essa discussão como encerrada/resolvida então.
Caso a resposta tenha te ajudado em algo faça uma avaliação dela e marque a discussão como resolvida
https://supportforums.cisco.com/docs/DOC-21307
Abraço
Cheers
Bruno Rangel
Primeiros Passos
