Buenos dias,
A mi tambien me esta sucediendo este problema
Tengo un problema con mis telefonos Cisco 7940, no me funciona la opción de autocompletar el numero, ( Configuring Auto Complete Number ), el firmware es el siguiente: P00308010200 con protocolo SCCP.
Mi Call Manager es: System version: 7.1.5.20000-6
Antes tenia la funcionalidad de autocompletar numeros marcados en el historial del telefono.
Por ejemplo, yo habbia llamado al 1234567 y con la funcion autocompletar cuando marcaba 123 me mostraba las llamadas que coincidian cone se patron en el display del telefono.
Good morning,
Me too me this problem is happening
I have a problem with my Cisco 7940 phone, I do not work the auto-number, (Configuring Auto Complete Number), the firmware is: P00308010200 with SCCP protocol.
My Call Manager is: System version: 7.1.5.20000-6
Before the autocomplete had numbers marked on the history of the phone.
For example, habbia call to 1234567 and the autocomplete function calls When I Scored 123 Showed That coincided cone is the pattern on the phone display.
Thank you for your anticipated support.
You can configure your phone to automatically complete the phone number being dialed by using the Auto Complete Number feature.
Perform the following steps to configure the Auto Complete Number feature.
Step 1 Press the settings button.
Step 2 Press the Scroll key to highlight Call Preferences.
Step 3 Press the Select softkey.
Step 4 Press the Scroll key to highlight Auto Complete Number from the Call Preferences menu.
Step 5 To enable the Auto Complete Number feature, press the Yes softkey. To disable the feature, press the No softkey.
Step 6 Press the Save softkey to save your selection of this feature and display the Settings menu.
Step 7 Press the Back softkey to display the main LCD screen. .
Hola,
Cuando mencionas que antes tenías la funcionalidad que firmware estabas utilizando?
Al parecer esta opción es para firmwares SIP:
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cuipph/7960g_7940g/sip/english/user/guide/user/sipuget.html#wp1053848
Saludos
Buenas,
Era el mismo software, yo no logre verlo, el usuario me lo afirmaba. De todos modos igual lo intente probar con el protocolo SIP pero de igual modo no nos habilitada las softkey y no se podia configurar las opciones anteriormente detalladas.
Optamos por poner un terminal mas avanzado 7962 y la función de automarcado funciona con normalidad y sin realizar modificación.
good,
It was the same software, I see it fails, the user claimed me. Anyway just try try SIP but equally not enabled us soft and could not configure the options detailed above.
We opted to put a more advanced terminal 7962 autodial function and operate normally without making changes.
Thanks and regards.
Gracias y saludos.
