2821 Lan2Lan VPN3030 redundancy?
jcmattos1
We have a remote site with dual 2821 ISR which we would like to connect to a single VPN3030 Concentrator with Lan2Lan. However we have 2 local ISP's, what would be the best vpn redundancy solution with dual 2821's and two ISP's that are terminated on the same 3750 switch? Any help is appreciated...Thx!
puagarwa
on 3030 in the L2L settings you have an option to configure multiple backup peers...but this will make the concentrator a "Anser Only" headend which means that you will have to iniiate the vpn from the router side. s you can configure the 2 2821 different ISP outside address there.
do tell me if this answers your question.
That sounds good! However, is this a global change? Will this affect other lan2lans on this concentrator? Do you happen to have examples or white papers on this multiple backup peers 3000VPN setup? Thx!
