Cisco Community Designated VIP Class of 2020
142
Beginner
2821 Lan2Lan VPN3030 redundancy?
We have a remote site with dual 2821 ISR which we would like to connect to a single VPN3030 Concentrator with Lan2Lan. However we have 2 local ISP's, what would be the best vpn redundancy solution with dual 2821's and two ISP's that are terminated on the same 3750 switch? Any help is appreciated...Thx!
2 REPLIES 2
Beginner
Re: 2821 Lan2Lan VPN3030 redundancy?
on 3030 in the L2L settings you have an option to configure multiple backup peers...but this will make the concentrator a "Anser Only" headend which means that you will have to iniiate the vpn from the router side. s you can configure the 2 2821 different ISP outside address there.
do tell me if this answers your question.
Highlighted
Beginner
That sounds good! However, is this a global change? Will this affect other lan2lans on this concentrator? Do you happen to have examples or white papers on this multiple backup peers 3000VPN setup? Thx!
Content for Community-Ad
FusionCharts will render here
