881 - isakmp crypto module not available
chaordixinc
Hi.
I have a Cisco 881 ISR (CISCO881-SEC-K9) and have the advanced security license installed and enabled/active and in use (see screenshot).  However, the isakmp crypto module is not available.
cisco#crypto ?
  gdoi   GDOI related commands
  ipsec  IPSec
  key    Key related commands.
  pki    Public Key
Here's my output of "show version"
Cisco IOS Software, C880 Software (C880DATA-UNIVERSALK9-M), Version 15.0(1)M8, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Thu 16-Feb-12 02:58 by prod_rel_team
ROM: System Bootstrap, Version 12.4(22r)YB5, RELEASE SOFTWARE (fc1)
cisco uptime is 11 minutes
System returned to ROM by reload at 13:47:55 PCTime Wed Aug 22 2012
System restarted at 13:48:27 PCTime Wed Aug 22 2012
System image file is "flash:c880data-universalk9-mz.150-1.M8.bin"
Last reload type: Normal Reload
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 881 (MPC8300) processor (revision 1.0) with 236544K/25600K bytes of memory.
Processor board ID FTX1624812T
5 FastEthernet interfaces
1 Virtual Private Network (VPN) Module
256K bytes of non-volatile configuration memory.
125440K bytes of ATA CompactFlash (Read/Write)
License Info:
License UDI:
Device#            PID                              SN
*0              CISCO881-SEC-K9       FTX1624812T
License Information for 'c880-data'
    License Level: advsecurity   Type: Permanent
    Next reboot license Level: advsecurity
What kind of module are you missing? Or are you missing the command "crypto isakmp" which is not available in your printout?
If it's just the command, then go to conf-mode where you can configure isakmp and find the "crypto isakmp ..." commands.
Hi Karsten.
User error, just as I figured. I needed to be in "config" mode to do the setup, and it's working now (well, mostly, I have a routing issue, but that's another thing completely).
Todd
