AnyConnect Certificate for mobile devices
tranminhc
Hi everyone,
I'm configuring Cisco Asa AnyConnect VPN, i have internal CA Server. Asa uses the CA certificate.
With windows machine users, after trust the CA, i can easily create certificate request file , import and issue it at CA server, and export that certificate to file and import it at the user machine. User can use anyconnect with Cert.
But with mobile device users (IOS and Android), i don't know how to create certificate for them.
Pls help me.
Thanks.
Here are some links that might help you out.
Android
http://www.cisco.com/c/en/us/td/docs/security/vpn_client/anyconnect/anyconnect30/user/xmart/b_Android_User_Guide/b_Android_User_Guide_chapter_0110.html#task_E2766A68CF97436081CCB10952A74318
iPhone
http://www.cisco.com/c/en/us/td/docs/security/vpn_client/anyconnect/anyconnect24/iphone-user/guide/iphone-anyconnect-ug-24.html#wp49157
Please remember to select a correct answer and rate helpful posts
Hi MariusGunnerud,
Thanks for your reply.
I know these documents. But i need to know how to create mobile device users certificate.
I've got more or less the same question. I've found this one :
http://networklessons.com/wireless/eap-tls-certificates-for-wireless-on-android/
I guess you were using a GPO for the windows machines, this how to show you how to do this manually for mobiles.
