Anyconnect connection issue
tksupport
Have a really strange issue.
After the first install ( Pre-Deploy ) of Anyconnect, entering domain name in "Connect" field, and pressing "Connect" - it connects without issues.
Then I press Disconnect and try to connect again - it complains that it can not connect and I should contact my ISP or aks me to Authenticae via Web.
If I change domain name in "Connection" fielt to one that does not exists and press Connect - it complains about same thing - that I should contact my ISP or Authenticate via Web.
Pressing again - it says that it can not resolve domain name. Then typing/choosing the domain name to which I connect after install - and it connects without issues.
Seems to have to do with some kind of caching.
is this is a normal behaviour ?
Anyconnect version: 3.1
Cisco ASA 5520, OS Version: 8.4
Client Operating SYstem: Windows 7
Thakn you.
tksupport
Seems that the issue was in that I press "Connect" after "Disconnect" too early. If I wait 5-10 seconds, it connects fine.
Thank you.
