10-23-2014 04:25 AM - edited 02-21-2020 07:53 PM
I have a strange issue with anyconnect. Anyconnect is based on radius credientials. When I login through portal it's working correctly, I can connect to vpn without any problems. But when I want to connect directly from anyconnect client it asking for credentials and don't want to connect. Credientials arfe valid.
[2014-10-23 13:04:02] Ready to connect.
[2014-10-23 13:06:20] Contacting 77.65.5.226.
[2014-10-23 13:06:45] Please enter your username and password.
[2014-10-23 13:06:53] User credentials entered.
[2014-10-23 13:07:28] Please enter your username and password.
[2014-10-23 13:22:55] User credentials entered.
[2014-10-23 13:23:49] Please enter your username and password.
[2014-10-23 13:23:55] User credentials prompt cancelled.
[2014-10-23 13:23:55] Ready to connect.
What could cause this issue, do I missed something in configuration?
Thanks in advance
10-24-2014 04:34 AM
I am guessing you have the following configured for the relevant tunnel-group?
tunnel-group ExampleGroup1 general-attributes
authentication-server-group <SERVER GROUP>
Would you be able to post a sanitised running config for us to look over?
Please remember to select a correct answer and rate helpful posts
10-24-2014 05:49 AM
Thanks for response
I guess this is config form ASA, I have anyconnect on 1921 router. Config:
webvpn gateway gateway_1
ip address XXX
http-redirect port 80
ssl trustpoint TP-self-signed-1662321223
inservice
webvpn context webvpn
secondary-color white
title-color #669999
text-color black
virtual-template 6
aaa authentication list ciscocp_vpn_xauth_ml_1
gateway gateway_1
ssl authenticate verify all
inservice
policy group policy_1
functions svc-enabled
svc address-pool "SDM_POOL_1" netmask 255.255.255.255
svc default-domain "XXX"
svc keep-client-installed
--svc split include 192.168.55.0 255.255.255.0
svc split include 192.168.66.0 255.255.255.0
svc dns-server primary 192.168.55.12
svc dns-server secondary 192.168.55.41
default-group-policy policy_1
aaa authentication login ciscocp_vpn_xauth_ml_1 group sdm-vpn-server-group-1 local
10-25-2014 12:01 PM
10-27-2014 07:24 AM
I found issue. In configuration were two radius servers, first of them was unavailable.
09-13-2017 05:48 AM
I am also having the same problem. what was your resolution for this
06-20-2018 12:00 AM
I am sure you would have figured out the issue but I faced the same issue and found my license had expired.
11-08-2018 02:40 PM
I faced same problem. There was an error in the authorization policy on ACS. We use cisco-av-pair and there was a mistake in one rule of de ACL on Radius attribute.
After correct that, client VPN could connect.
09-16-2019 04:22 AM
When I received this same message while attempting to login via VPN, it turned out that I simply needed to reactivate my two-factor authentication account. Once reactivated, I was able to login without issue.
03-04-2021 12:49 AM
I had the same issue with one our client and his AD password were expired. After resetting his password which worked fine.
