Beginner
I know this is old post, but
I know this is old post, but I am having exactly the same issue. See link below
https://supportforums.cisco.com/discussion/12479401/asa-5505-version-915-ipsec-remote-vpn-ikev2
How was this resolved?
Beginner
Anyconnect IPSEC error unauthorized connection mechanism
Is anyone else having a solution for me ?
Thx
Highlighted
Beginner
Hi Abissi,
I have not given up yet !!!!
When you login with the IP sec profile, do you use the certificate ? if then
1) Check do we have the same certificate on asa.
2) Change the user authentication in GP to cert because right now it is local.
Nitin Mohan
Beginner
found a very good article that might help
https://supportforums.cisco.com/docs/DOC-18960
Beginner
Already found this article. That's exactly what i've done unfortunately without success
Beginner
Hi Nitin,
I only use local authentication, no certificate.
R.
