12-29-2013 12:19 PM
Hi everyone,
I'm trying to configure Anyconnect connection on my ASA 5505 (ASA 9.1.3, ASDM 7.1.4).
The goal is to have 2 connection, one for IPSEC and the other one for SSL.
SSL connection work fine but IPSEC won't work. When i try to connect i receive error "Login denied, unauthorized connection mechanism"
I can't find what i'm doing wrong. Both configurations have been done with the Anyconnect wizard.
Can you help me please ? I'm new in Cisco world ...
Thx in advance
Here's my config :
ASA Version 9.1(3)
hostname CiscoASA
enable password ***** encrypted
xlate per-session deny tcp any4 any4
xlate per-session deny tcp any4 any6
xlate per-session deny tcp any6 any4
xlate per-session deny tcp any6 any6
xlate per-session deny udp any4 any4 eq domain
xlate per-session deny udp any4 any6 eq domain
xlate per-session deny udp any6 any4 eq domain
xlate per-session deny udp any6 any6 eq domain
passwd ***** encrypted
names
ip local pool VPN-Pool 10.104.106.1-10.104.106.10 mask 255.255.255.0
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
switchport access vlan 3
interface Vlan1
nameif inside
security-level 100
ip address 10.4.6.254 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address dhcp setroute
interface Vlan3
no forward interface Vlan1
nameif DMZ
security-level 50
ip address 10.4.106.254 255.255.255.0
boot system disk0:/asa913-k8.bin
ftp mode passive
clock timezone CEST 1
clock summer-time CEDT recurring last Sun Mar 2:00 last Sun Oct 3:00
dns domain-lookup inside
dns domain-lookup outside
dns domain-lookup DMZ
dns server-group DefaultDNS
name-server 8.8.8.8
name-server 8.8.4.4
object network NETWORK_OBJ_10.104.106.0_28
subnet 10.104.106.0 255.255.255.240
object network NETWORK_OBJ_10.4.6.0_24
subnet 10.4.6.0 255.255.255.0
access-list outside_access_in remark Remote access to Cloudstation
access-list outside_access_in extended permit object Cloudstation object-group Cloudstation-Access object Synology-Cloudstation
access-list Anyconnect standard permit 10.4.6.0 255.255.255.0
access-list AnyConnect_Client_Local_Print extended deny ip any4 any4
access-list AnyConnect_Client_Local_Print extended permit tcp any4 any4 eq lpd
access-list AnyConnect_Client_Local_Print remark IPP: Internet Printing Protocol
access-list AnyConnect_Client_Local_Print extended permit tcp any4 any4 eq 631
access-list AnyConnect_Client_Local_Print remark Windows' printing port
access-list AnyConnect_Client_Local_Print extended permit tcp any4 any4 eq 9100
access-list AnyConnect_Client_Local_Print remark mDNS: multicast DNS protocol
access-list AnyConnect_Client_Local_Print extended permit udp any4 host 224.0.0.251 eq 5353
access-list AnyConnect_Client_Local_Print remark LLMNR: Link Local Multicast Name Resolution protocol
access-list AnyConnect_Client_Local_Print extended permit udp any4 host 224.0.0.252 eq 5355
access-list AnyConnect_Client_Local_Print remark TCP/NetBIOS protocol
access-list AnyConnect_Client_Local_Print extended permit tcp any4 any4 eq 137
access-list AnyConnect_Client_Local_Print extended permit udp any4 any4 eq netbios-ns
pager lines 24
logging enable
logging asdm informational
logging from-address cisco@rabinformatique.be
logging recipient-address raphael.abissi@rabinformatique.be level errors
mtu inside 1500
mtu outside 1500
mtu DMZ 1500
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-714.bin
asdm history enable
arp timeout 14400
no arp permit-nonconnected
nat (inside,outside) source static NETWORK_OBJ_10.4.6.0_24 NETWORK_OBJ_10.4.6.0_24 destination static NETWORK_OBJ_10.104.106.0_28 NETWORK_OBJ_10.104.106.0_28 no-proxy-arp route-lookup
nat (inside,outside) source static any any destination static NETWORK_OBJ_10.104.106.0_28 NETWORK_OBJ_10.104.106.0_28 no-proxy-arp route-lookup
object network Synology-Cloudstation
nat (inside,outside) static interface service tcp 6690 6690
nat (inside,outside) after-auto source dynamic any interface
access-group outside_access_in in interface outside
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
aaa authentication ssh console LOCAL
http server enable
http 10.4.6.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
crypto ipsec ikev1 transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec ikev2 ipsec-proposal AES256
protocol esp encryption aes-256
protocol esp integrity sha-1 md5
crypto ipsec ikev2 ipsec-proposal AES192
protocol esp encryption aes-192
crypto ipsec ikev2 ipsec-proposal 3DES
protocol esp encryption 3des
crypto ipsec ikev2 ipsec-proposal DES
protocol esp encryption des
crypto ipsec security-association pmtu-aging infinite
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set ikev1 transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set ikev2 ipsec-proposal AES256 AES192 AES 3DES DES
crypto map outside_map 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map outside_map interface outside
crypto map inside_map 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map inside_map interface inside
crypto ca trustpoint VPN
enrollment self
subject-name CN=*****
keypair VPN
crl configure
crypto ca trustpoint SSH
enrollment self
subject-name CN=10.4.6.254
crl configure
crypto ca trustpoint ASDM_TrustPoint0
enrollment self
subject-name CN=***
keypair SSL
crl configure
crypto ca trustpool policy
crypto ca certificate chain VPN
certificate 8d31a352
quit
crypto ca certificate chain SSH
certificate 8c27bc52
quit
crypto ca certificate chain ASDM_TrustPoint0
certificate 730fbe52
quit
crypto ikev2 policy 1
encryption aes-256
integrity sha
group 5 2
prf sha
lifetime seconds 86400
crypto ikev2 policy 10
encryption aes-192
integrity sha
group 5 2
prf sha
crypto ikev2 policy 20
encryption aes
integrity sha
group 5 2
prf sha
crypto ikev2 policy 30
encryption 3des
integrity sha
group 5 2
prf sha
crypto ikev2 policy 40
encryption des
integrity sha
group 5 2
prf sha
crypto ikev2 enable inside client-services port 443
crypto ikev2 enable outside client-services port 443
crypto ikev2 remote-access trustpoint ASDM_TrustPoint0
crypto ikev1 policy 10
authentication crack
encryption aes-256
hash sha
group 2
lifetime 86400
crypto ikev1 policy 20
authentication rsa-sig
encryption aes-256
hash sha
group 2
lifetime 86400
crypto ikev1 policy 30
authentication pre-share
encryption aes-256
hash sha
group 2
lifetime 86400
crypto ikev1 policy 40
encryption aes-192
hash sha
group 2
lifetime 86400
crypto ikev1 policy 50
encryption aes-192
hash sha
group 2
lifetime 86400
crypto ikev1 policy 60
encryption aes-192
hash sha
group 2
lifetime 86400
crypto ikev1 policy 70
encryption aes
hash sha
group 2
lifetime 86400
crypto ikev1 policy 80
encryption aes
hash sha
group 2
lifetime 86400
crypto ikev1 policy 90
encryption aes
hash sha
group 2
lifetime 86400
crypto ikev1 policy 100
encryption 3des
hash sha
group 2
lifetime 86400
crypto ikev1 policy 110
encryption 3des
hash sha
group 2
lifetime 86400
crypto ikev1 policy 120
encryption 3des
hash sha
group 2
lifetime 86400
crypto ikev1 policy 130
encryption des
hash sha
group 2
lifetime 86400
crypto ikev1 policy 140
encryption des
hash sha
group 2
lifetime 86400
crypto ikev1 policy 150
encryption des
hash sha
group 2
lifetime 86400
telnet 10.4.6.0 255.255.255.0 inside
telnet timeout 5
ssh 10.4.6.0 255.255.255.0 inside
ssh timeout 5
ssh key-exchange group dh-group1-sha1
console timeout 0
dhcpd dns 8.8.8.8
dhcpd address 10.4.6.10-10.4.6.100 inside
dhcpd dns 8.8.8.8 8.8.4.4 interface inside
dhcpd enable inside
threat-detection basic-threat
threat-detection statistics host
threat-detection statistics port
threat-detection statistics protocol
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
ntp server 132.163.4.102 source outside
ssl trust-point ASDM_TrustPoint0 inside
ssl trust-point ASDM_TrustPoint0 outside
webvpn
enable inside
enable outside
anyconnect image disk0:/anyconnect-win-3.1.04072-k9.pkg 1
anyconnect profiles IPSEC_client_profile disk0:/IPSEC_client_profile.xml
anyconnect profiles SSL_client_profile disk0:/ssl_client_profile.xml
anyconnect enable
tunnel-group-list enable
group-policy DfltGrpPolicy attributes
dns-server value 8.8.8.8
webvpn
anyconnect ssl compression deflate
group-policy GroupPolicy_SSL internal
group-policy GroupPolicy_SSL attributes
wins-server none
dns-server value 8.8.8.8 8.8.4.4
vpn-tunnel-protocol ssl-client
split-tunnel-policy tunnelspecified
split-tunnel-network-list value Anyconnect
default-domain none
webvpn
anyconnect profiles value SSL_client_profile type user
group-policy GroupPolicy_IPSEC internal
group-policy GroupPolicy_IPSEC attributes
wins-server none
vpn-tunnel-protocol ikev2
default-domain none
webvpn
anyconnect profiles value IPSEC_client_profile type user
username test password ***** encrypted
username test attributes
service-type remote-access
username raphael password ***** encrypted
username admin password gM8SqVAvFPseIv5v encrypted privilege 15
username administrator password ***** encrypted privilege 15
tunnel-group SSL type remote-access
tunnel-group SSL general-attributes
address-pool VPN-Pool
default-group-policy GroupPolicy_SSL
tunnel-group SSL webvpn-attributes
group-alias SSL enable
tunnel-group IPSEC type remote-access
tunnel-group IPSEC general-attributes
default-group-policy GroupPolicy_IPSEC
tunnel-group IPSEC webvpn-attributes
group-alias IPSEC enable
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum client auto
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
inspect ip-options
service-policy global_policy global
smtp-server 212.68.193.11
prompt hostname context
no call-home reporting anonymous
call-home
profile CiscoTAC-1
no active
destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
destination address email callhome@cisco.com
destination transport-method http
subscribe-to-alert-group diagnostic
subscribe-to-alert-group environment
subscribe-to-alert-group inventory periodic monthly
subscribe-to-alert-group configuration periodic monthly
subscribe-to-alert-group telemetry periodic daily
Cryptochecksum:9d5177ddc09025d07f9d5c1c2f7747e0
: end
CiscoASA#
04-15-2015 06:56 PM
I know this is old post, but I am having exactly the same issue. See link below
https://supportforums.cisco.com/discussion/12479401/asa-5505-version-915-ipsec-remote-vpn-ikev2
How was this resolved?
01-10-2014 12:25 AM
Is anyone else having a solution for me ?
Thx
01-10-2014 05:23 AM
Hi Abissi,
I have not given up yet !!!!
When you login with the IP sec profile, do you use the certificate ? if then
1) Check do we have the same certificate on asa.
2) Change the user authentication in GP to cert because right now it is local.
Nitin Mohan
01-10-2014 08:22 AM
found a very good article that might help
01-12-2014 04:16 AM
Already found this article. That's exactly what i've done unfortunately without success
01-12-2014 04:15 AM
Hi Nitin,
I only use local authentication, no certificate.
R.
