Highlighted
Beginner
Anyconnect Premium License Issue
we have just added 30 Anyconenct premium License APEX Linensing and cannot get more than 4 Connections
we see this
VPN Licenses and Configured Limits Summary
Status : Capacity : Installed : Limit
AnyConnect Premium : ENABLED : 250 : 250 : 4
AnyConnect Essentials : DISABLED : 250 : 250 : 4
Other VPN (Available by Default) : ENABLED : 250 : 250 : 250
Shared License Server : DISABLED
Shared License Participant : DISABLED
AnyConnect for Mobile : ENABLED(Requires Premium or Essentials)
Advanced Endpoint Assessment : ENABLED(Requires Premium)
AnyConnect for Cisco VPN Phone : ENABLED
VPN-3DES-AES : ENABLED
VPN-DES : ENABLED
 Why are we still limited to 4 Connections?
version
Cisco Adaptive Security Appliance Software Version 9.0(3)
Device Manager Version 7.1(3)
1 REPLY 1
Re: Anyconnect Premium License Issue
Hi  twstevensuk,
Try checking the following command:
sh run all vpn-sessiondb
If you see a vpn-sessiondb max... with the limit of 4 just remove the command to disable the vpn-session limit:
no vpn-sessiondb max-anyconnect-premium-or-essentials-limit
-JP-
If helps please rate!
